Had a fault appear on my 2007 A6 saloon.
Brake light warning on the dash (with that really annoying beep on start up!). However brake lights all fine - eve n had them off to check terminals etc.
How do I reset it to stop it bleeping/flashing the warning...? or does anyone know a solution?
My fog lights always give me a warning, one after the other.
If I turn them on the warning goes away.
I know what the cause is and I could fit resistors to cure it, but it don't bother me that much. It's because I fitted LED's.
You may have a power drop on the light that's causing it.
Try fitting a separate ground wire to that light.
Hello Steve,
You may (in caps) have two brake light bulbs per side - worth a check.
Also check for poor contacts and good earths. Use contact cleaner as necessary.
20 minutes ago, Magnet said:
Hello Steve,
Funny you should say that - as the two bulbs was the issue. One had failed and so brake light appeared to still work.
Swapped a new bulb in - sorted for a total of £1..!
Thanks Steve,
Just as well I posted, so at least others will now know what the solution was.
