Sarge B Posted May 19, 2022 Posted May 19, 2022 Had a fault appear on my 2007 A6 saloon. Brake light warning on the dash (with that really annoying beep on start up!). However brake lights all fine - eve n had them off to check terminals etc. How do I reset it to stop it bleeping/flashing the warning...? or does anyone know a solution?
RoyC Posted June 1, 2022 Posted June 1, 2022 On 5/19/2022 at 7:58 PM, Sarge B said: Had a fault appear on my 2007 A6 saloon. Brake light warning on the dash (with that really annoying beep on start up!). However brake lights all fine - eve n had them off to check terminals etc. How do I reset it to stop it bleeping/flashing the warning...? or does anyone know a solution? Expand My fog lights always give me a warning, one after the other. If I turn them on the warning goes away. I know what the cause is and I could fit resistors to cure it, but it don't bother me that much. It's because I fitted LED's. You may have a power drop on the light that's causing it. Try fitting a separate ground wire to that light. 1
Magnet Posted June 1, 2022 Posted June 1, 2022 Hello Steve, You may (in caps) have two brake light bulbs per side - worth a check. Also check for poor contacts and good earths. Use contact cleaner as necessary. Kind regards, Gareth.
Sarge B Posted June 1, 2022 Author Posted June 1, 2022 On 6/1/2022 at 8:57 AM, Magnet said: Hello Steve, You may (in caps) have two brake light bulbs per side - worth a check. Also check for poor contacts and good earths. Use contact cleaner as necessary. Kind regards, Gareth. Expand Funny you should say that - as the two bulbs was the issue. One had failed and so brake light appeared to still work. Swapped a new bulb in - sorted for a total of £1..! 1
Magnet Posted June 1, 2022 Posted June 1, 2022 Thanks Steve, Just as well I posted, so at least others will now know what the solution was. Kind regards, Gareth.
