Tony Barnes Posted May 23, 2022 Posted May 23, 2022 time to have the front bumper off and check all the wiring and sensors, getting a fault code of 02069 - Front Parking Aid Sensors, open circuit, cleared off 23 seperate historic fault codes, drove it a good thirty miles and the only one to return is the parking assist.
Steve Q Posted May 24, 2022 Posted May 24, 2022 12 hours ago, Tony Barnes said: time to have the front bumper off and check all the wiring and sensors, getting a fault code of 02069 - Front Parking Aid Sensors, open circuit, cleared off 23 seperate historic fault codes, drove it a good thirty miles and the only one to return is the parking assist. Glad all the others cleared. It's most likely a sensor. But definitely check for broken wiring. Last resort it could be the module.
Tony Barnes Posted May 24, 2022 Author Posted May 24, 2022 18 minutes ago, Steve Q said: Glad all the others cleared. It's most likely a sensor. But definitely check for broken wiring. Last resort it could be the module. Not a sound from any of the sensors, so looking for likely a broken wire, I'll just strip it out and test it through.
Steve Q Posted May 24, 2022 Posted May 24, 2022 16 minutes ago, Tony Barnes said: Not a sound from any of the sensors, so looking for likely a broken wire, I'll just strip it out and test it through. Good plan 🙂 please keep us posted on how you get on 🙂
Tony Barnes Posted May 30, 2022 Author Posted May 30, 2022 had the front bumper off today, unpluged everything and checked the connections, re pluged them in, cleared the fault code and it came back instantly, tried to test the circuit but it won't let you while it has a fault code..... might end up just having to live with it, audi want £110.00 to look at at to tell me whats wrong with it..... and thats without repairing it, i know what they will do, new harness..... new sensors...... new module..... and that'll be nearly £2000.
RoyC Posted May 30, 2022 Posted May 30, 2022 11 minutes ago, Tony Barnes said: had the front bumper off today, unpluged everything and checked the connections, re pluged them in, cleared the fault code and it came back instantly, tried to test the circuit but it won't let you while it has a fault code..... might end up just having to live with it, audi want £110.00 to look at at to tell me whats wrong with it..... and thats without repairing it, i know what they will do, new harness..... new sensors...... new module..... and that'll be nearly £2000. Make sure that the groove separating the center and the outer ring on the sensors is clean. Every time that I wax my car I get a stiff tooth brush and brush the sensors.
Tony Barnes Posted May 30, 2022 Author Posted May 30, 2022 1 hour ago, RoyC said: Make sure that the groove separating the center and the outer ring on the sensors is clean. Every time that I wax my car I get a stiff tooth brush and brush the sensors. Yes just tried that, no joy.
RoyC Posted May 30, 2022 Posted May 30, 2022 1 hour ago, Tony Barnes said: Yes just tried that, no joy. Oh well, worth a go.
RoyC Posted May 30, 2022 Posted May 30, 2022 1 hour ago, Tony Barnes said: Yes just tried that, no joy. I suppose that you have already checked out the videos on youtube.
Tony Barnes Posted May 30, 2022 Author Posted May 30, 2022 1 hour ago, RoyC said: I suppose that you have already checked out the videos on youtube. Yes, watched them.
Steve Q Posted May 31, 2022 Posted May 31, 2022 I'd recommend getting it to an auto electrican as they'll be cheaper. Well done for having a go at sorting it though 🙂
