Starting issues on morning
miller31968
My 2016 a4 avant has started to cause problems on a morning.
I put the dogs in the boot first and then when I get in car it refuses to start on the button. I have to get in and out again for car to start. An uadi safelock warning comes up. I have had the car for a year and has only just started doing this.
It could be a failing jet battery. I'd look at getting new battery in the fob and then reset the key. A good way to determine if it is the key is to see if the same issue occurs with the spare key.
  • Thanks 1
Top tip - Having nearly been stranded when the remote for my motorbike's immobiliser failed, I now replace the batteries on the remotes for my cars when I get them MoTed...
