Tony Barnes Posted May 24, 2022 Posted May 24, 2022 Ok, so that's not exactly true, it will open with the switch in the car or if you use the button on the boot, but it just won't ppen when you press the key button, any thoughts? Thank you.
Steve Q Posted May 24, 2022 Posted May 24, 2022 I'd recommend a diagnostic check to see if any fault codes flag up. It could be an issue with the key and the easiest way to check is to try and activate the boot with the spare key. Alternatively it could be the actuator in the boot mechanism.
Tony Barnes Posted May 24, 2022 Author Posted May 24, 2022 all sorted, removed the actuators, cleaned and greased and good as new 😁 1
Steve Q Posted May 25, 2022 Posted May 25, 2022 On 5/24/2022 at 6:54 PM, Tony Barnes said: all sorted, removed the actuators, cleaned and greased and good as new 😁 Expand There you are 🙂 so glad when it's an easy fix 🙂 1
JMKC82 Posted May 25, 2022 Posted May 25, 2022 i'm glad it's sorted, but confused how cleaning the actuator sorted the boot not opening with the key? 😄
Macca51 Posted December 9, 2023 Posted December 9, 2023 Problem with A6 21 auto boot opening. Can hear the release trying /clicking , but not releasing or opening .
