dalswinton Posted May 27, 2022 Posted May 27, 2022 Hi , I have a A4 Allroad b9 2017, 190tdi engine, does anyone know if there is room to fit a space saver wheel under the boot floor, in place of the callapsible spare, many thanks Brian.
Stevey Y Posted May 27, 2022 Posted May 27, 2022 8 hours ago, dalswinton said: Hi , I have a A4 Allroad b9 2017, 190tdi engine, does anyone know if there is room to fit a space saver wheel under the boot floor, in place of the callapsible spare, many thanks Brian. Hi if the battery is under the collapsible wheel I seriously doubt it, in saying that you may be able to fit a space saver you just have to do some serious measuring between the middle highest point on your existing wheel using flat steel rule and the edge of the boot floor that will give you a ball park idea of how much room you have to play with, then you have to find out the total profile of the intended space saver and work back from there, in theory it should work as both steel rims space saver/collapsible should be the same. Steve.
