Hi i have a audi a1 2016 1.4tfsi when i am inside car and i get out to open back passenger door or boot its locked i have to use key. Also when someone tries getting in car the doors are locked from inside is there a button to use i have seen a button near drivers side door lock unlock聽
It could be an issue with a door module. Most likely drivers door module as that's the one controls the rest of the doors. I'd also recommend a diagnostic check to see if any fault codes flag up.聽
  • 2 months later...
On drivers door do you have two buttons one with a locked padlock 馃敀 and one with an open padlock ? I have to use the open button to open the boot .
  • Thanks 1
