andydin68 Posted June 8, 2022 Posted June 8, 2022 My 2016 A6 Allroad now has a noise that humming/whining sounds like a front wheel bearing. The car has only done 46000 miles. Is it a common problem or am I just unlucky? Anyway an idea of potential repair costs would be appreciated.
K3v Posted June 8, 2022 Posted June 8, 2022 HI pretty sure that wheel bearings are known to not last that long on the a6, Couldn't help with a cost though, mine haven't gone yet.
andydin68 Posted July 1, 2022 Author Posted July 1, 2022 Just over £200 to get a front wheel bearing replaced by an independent Audi specialist. Mechanic said it was "a hell of a job"
Magnet Posted July 1, 2022 Posted July 1, 2022 Does that include the cost of the part Andy? - hub complete with bearing replaced, or just bearing? Kind regards, Gareth.
andydin68 Posted July 1, 2022 Author Posted July 1, 2022 That was the price including parts. Wheel bearing was £43 + VAT
Magnet Posted July 1, 2022 Posted July 1, 2022 Sounds like they fitted new bearings into your old hub then. Rather a labour intensive way of doing it.
andydin68 Posted July 1, 2022 Author Posted July 1, 2022 6 minutes ago, Magnet said: Sounds like they fitted new bearings into your old hub then. Rather a labour intensive way of doing it. Probably why it was a "hell of a job" 🤨
Lidiven12 Posted July 6, 2022 Posted July 6, 2022 Ive had many trouble in the past with wheel bearings which usually go in pairs. The cost from a mechanic can vary, but fitted them myself which might be a cheaper option for you if you know what your doing. Its quite simple if you've looked at a few tutorials. The bearings https://www.spareshut.com/collections/wheel-bearings here were the cheapest i found so its at least worth a look.
