FIRST SCAN
RoyC
Finally managed to get a scan.
Trouble is, it don't mean a thing to me, haha.
Friday,10,June,2022,14:59:17:31033
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WAUZZZ4F19N036857   License Plate: BK09UPC
Mileage: 68120km-42327mi   Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
          62 72 76
VIN: WAUZZZ4F19N036857   Mileage: 68120km-42327miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (CAN)       Labels:. 059-907-401-CAN.clb
   Part No SW: 4F7 910 401 K    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17G000CG  0090
   Revision: 16H01---    Serial number:
   Coding: 010D002C02070128
   Shop #: WSC 18432 423 592680
   VCID: 2B5F28B68A7C09D74A-807E
   VINID: 9D196AAAA1160497800C62051CEFFC287A
3 Faults Found:
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
053286 - Please Check Fault Codes in Transmission Control Module
               U1026 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 007 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 4F5 910 157 H    HW: 01J 927 156 JG
   Component: V30 0AN 2.7lTDI RdW 0010
   Revision: --H05---    Serial number: 00000000000328
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2E5921A2B96E7CFF6D-807A
1 Fault Found:
006168 - Pressure Control Valve 2
               P1818 - 006 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100110
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 96 /min
                    RPM: 0 /min
                    (no units): 13.0
                    Torque: -48.0 Nm
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Component: ESP8 front      H03 0060
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0020876
   VCID: 6DDBE6AE74E8C7E714-8038
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 174
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601261827
   Coding: 0000147
   Shop #: WSC 02324 785 00200
   VCID: 254BDE8EEC983FA79C-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
No fault code found.
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F2 820 043 AA
   Component: KLIMABETAETIGUNGH30 0070
   Revision: 00000073    Serial number: 00000000601444
   Coding: 0001302
   VCID: 1D3BF66EC4C8F767C4-8048
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0013121
   Shop #: WSC 02335 785 00200
   VCID: 346D33CA5742562F1B-8060
   Subsystem 1 - Part No: 4F2 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH04 0003
   Coding: 00146221
   Shop #: WSC 02335
3 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00110111
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 159
                    Mileage: 66828 km
                    Time Indication: 0
                    Date: 2019.08.26
                    Time: 06:43:00
01496 - Bulb for Fog-Lamps; Left (L22)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00111010
                    Fault Priority: 2
                    Fault Frequency: 102
                    Reset counter: 196
                    Mileage: 66592 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:00
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 89
                    Reset counter: 196
                    Mileage: 66732 km
                    Time Indication: 0
                    Date: 2019.05.19
                    Time: 08:38:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H47 0050
   Revision: 00000012
   VCID: 2143CA9E38B0D387E0-8074
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 30314236303630303033554A305234463053
   ASAM Dataset: EV_Airba10AURB4 001001
   ROD: EV_Airba10AURB4.rod
   VCID: 30653FDA6B5A6A0F7F-8064
   Crash sensor for side airbag: driver side:
   Serial number: 3574SRB400008495215.
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 3584SRB40000849D397E
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 35152RB402J838NMVR2V
   Passenger side rear thorax airbag crash sensor:
   Serial number: 35252RB402P838NMV35H
   Crash sensor for front airbag: driver side:
   Serial number: 3554NRB40000491848A/
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564NRB4000049100D8W
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90055083440101
   Coding: 0102142
   VCID: 2757D48696942DB7AE-8072
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 B    HW: 4F0 920 983 B
   Component: KOMBIINSTR.   H06 0135
   Revision: 00000000    Serial number: AE940E1D8
   Coding: 2F57110502002700010401
   Shop #: WSC 02391 823 56573
   VCID: 2B5F28B64A7C09D74A-807E
Address 19: CAN Gateway (J533)       Labels:. 4F0-907-468.clb
   Part No SW: 4F0 907 468 F    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0024
   Revision: 4LA70021    Serial number: 2100L0910680F4
   Coding: 000303
   VCID: 326135D26D56581F09-8066
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140408501
Address 42: Door Elect, Driver (J386)       Labels:. 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Component: TSG FA        H11 0250
   Revision:             Serial number: 0000100632175
   Coding: 011F06205041410001
   VCID: 46897902F1DED4BFB5-8012
1 Fault Found:
02115 - Locking Unit for Central Locking
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 133
                    Reset counter: 196
                    Mileage: 66580 km
                    Time Indication: 0
                    Date: 2019.03.22
                    Time: 11:29:58
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01166766660000
   Coding: 0140027
   VCID: 31633ADEA850630770-8064
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
5 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:22
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:22
01506 - Bulb for Rear Fog; Right (L47)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:23
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:45:15
01519 - Bulb for Back-Up Lights; Right (M17)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:45:38
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000002161
   Coding: 0F010000
   VCID: 2953D2BE40801BC7B8-807C
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000610073
   Coding: 0001103
   Shop #: WSC 02145 785 00200
   VCID: 5EB9B162894EAC7F9D-800A
Address 52: Door Elect, Pass. (J387)       Labels:. 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Component: TSG BF        H11 0250
   Revision:             Serial number: 0000100622308
   Coding: 011F06205C41410001
   VCID: 458B7E0ECCD8DFA7BC-8010
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000531
   VCID: 2143CA9EF8B0D387E0-8074
Address 55: Headlight Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 H
   Component: Dynamische LWR  H02 0010
   Revision: 00000001    Serial number:
   Coding: 0000003
   VCID: 3F876CE66E048577F6-806A
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H44 0020
   Revision: AB001007    Serial number: 341AQ097529712
   Coding: 010003010000000000
   VCID: 1C3DFB6A1FD2FE6F33-8048
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4E0 035 652 A    HW: 4E0 035 652
   Component: B-BN-EU       H47 0048
   Revision: --------    Serial number: 349A-097506098
   Coding: 010101010102C3FD43000F0DEF7300030001
   Shop #: WSC 00779 210 97010
   VCID: 1F47CC660EC4E577D6-804A
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355AC091013090
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F2 919 611 H
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001249242
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 66580 km
                    Time Indication: 0
                    Date: 2019.03.22
                    Time: 09:21:16
             Freeze Frame:
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000101
Address 62: Door, Rear Left (J388)       Labels:. 4F0-959-795.clb
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Component: TSG HL        H10 0251
   Revision:             Serial number: 0000100645651
   Coding: 010E04204041220001
   VCID: 438F6016C2ECE19792-8016
Address 72: Door, Rear Right (J389)       Labels:. 4F0-959-795.clb
   Component: TSG HR        H10 0251
   Revision:             Serial number: 0000100645097
Address 76: Park Assist        Labels: 4Fx-910-283.lbl
   Part No SW: 4L0 910 283 A    HW: 4L0 919 283 A
   Component: Parkhilfe 8-Kan H02 0400
   Revision: 00H02000    Serial number: 13630901502908
   Coding: 0201016
   VCID: 2855D7BA9B8A22CFA7-807C
1 Fault Found:
01544 - Indicator Lamp for Parking-Aid (K136)
            006 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 66980 km
                    Time Indication: 0
                    Date: 2019.10.31
                    Time: 12:02:34
www.Ross-Tech.com
          62 72 76
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:28
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Voltage: 12.92 V
                    Temperature: 8.1°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 42 /min
                    Speed: 0.0 km/h
                    Load: 56.9 %
                    Voltage: 10.56 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    RPM: 819 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Coding: 0000001
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 255
                    Mileage: 66825 km
                    Time Indication: 0
                    Date: 2019.08.19
                    Time: 06:30:07
             Freeze Frame:
                    RPM: 96 /min
                    RPM: 0 /min
                    (no units): 13.0
                    Torque: -48.0 Nm
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
   Coding: 0020876
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 174
                    Mileage: 67314 km
                    Time Indication: 0
                    Date: 2008.08.13
                    Time: 00:46:32
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x00FF
   Coding: 0000147
   Coding: 0001302
   Coding: 0013121
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 159
                    Mileage: 66828 km
                    Time Indication: 0
                    Date: 2019.08.26
                    Time: 06:43:00
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 196
                    Mileage: 66592 km
                    Time Indication: 0
                    Date: 2019.03.24
                    Time: 06:55:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 89
                    Reset counter: 196
                    Mileage: 66732 km
                    Time Indication: 0
                    Date: 2019.05.19
                    Time: 08:38:00
   Revision: 00000012
   Coding: 0102142
   Coding: 000303
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 196
                    Mileage: 66580 km
                    Time Indication: 0
                    Date: 2019.03.22
                    Time: 11:29:58
   Coding: 0140027
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:22
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:22
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:44:23
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:45:15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 67359 km
                    Time Indication: 0
                    Date: 2008.09.08
                    Time: 22:45:38
   Coding: 0F010000
   Coding: 0001103
   Revision: --H05---
   Coding: 0000531
   Coding: 0000003
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 66580 km
                    Time Indication: 0
                    Date: 2019.03.22
                    Time: 09:21:16
             Freeze Frame:
   Coding: 0201016
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 66980 km
                    Time Indication: 0
                    Date: 2019.10.31
                    Time: 12:02:34
Hi Roy you have a ton of fault codes and guess what they are all ancient, easiest thing to do is erase the lot as I doubt you will see them again as a current embedded fault may reappear more than twice thats when you have a problem so erase all DTCs and scan it again in a couple of weeks to see if you have any current faults.
Thanks Stevey, will do what you suggest.
Just a quicky, what do these reset numbers mean :-
Reset counter: 255
      Reset counter: 40
Reset counter: 255
      Reset counter: 40
Hi they are the amount of drive cycles stored after the fault, so as I said delete the codes as most of them are a one off and old, I would think your code storage must be about full as the counter numbers in theory should go down with each cycle within which the fault has not re occurred unless the memory is nearly full in which case they will remain stored with the original allocation number 255/40, therefore I cannot overstate the value of a once monthly scan and clearance of one time codes this will also give you a heads up with a failing component before it goes bang and ruins something else especially things like oxygen sensors, mine was occasionally throwing a fault but no EML so after I cleared it it reappeared a week later which was all I needed to be convinced replacement was the best option I could have just carried on clearing it until the thing failed completely and the car won't do any regeneration of the DPF therefore blocking it, timely replacement stops this happening along with a horrendous bill for a new DPF.
Cleared the codes today.
Got to bleed the ABS tomorrow.
BLEED ABS PUMP
 Procedure for Bleeding the ABS Brake Pump on VW Passat and Audi A4/S4, A6/S6, and A8/S8:
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 002
[Go!]
This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.
Click the [Done, Go Back] button and you're all set.
