Wheel size
Hello Nathan,
18 inch were probably an option, and I guess you know you will need to fit lower profile tyres than your current profiles on the 17 inch, to ensure the ‘rolling’ outside diameter remains the same. It would be worth checking in your handbook or tyre pressure sticker on the car, what the correct tyre size should be. I cannot see why any computer adjustments would then be necessary.
5 minutes ago, Magnet said:
Hello Nathan,
Thanks Gareth.
I’ve gone for a lower sidewall size so in theory they should be the same rolling radius.
Many thanks
Nath
Thanks Nathan,
I think I would be actually double checking/ working it out, since variations in rolling diameter will affect at least speedometer readings and possibly far more.
