Brake bleeding
RoyC
When bleeding brakes on a car with ABS, do you start on the wheel furthest away from the Reservoir or the one furthest away from the ABS ?
Hi if you bleed all for wheels at once it won't give the air bubbles in the system time to creep off elsewhere as its being flushed out, like I said you need a good supply of fluid and a litre gravity feed bottle in the master cylinder reservoir.
15 minutes ago, RoyC said:
I'm going to use a pressure bleeder.
Hi excellent just do all four, and please clear the fault codes its the only way forward, if you don't want to do it that way bleeding wise just do both rears first and then both fronts.
I'll do it tomorrow, I've been searching round to find four jars.
