runman99 Posted June 21, 2022 Posted June 21, 2022 Hi all, well am planning on doing the timing belt soon -ish ! I have got the big bar to lock the pulleys in place. Now starting to shop for the belt . tensioner etc. Any help from anyone who has done this before will be welcome. Cheers.
runman99 Posted June 21, 2022 Author Posted June 21, 2022 Thanks Kev, I meant any assistance as in 'Hints & tip' Best reliable sources ? To ensure correct part numbers etc ? 🙂
Magnet Posted June 21, 2022 Posted June 21, 2022 Hello Mathew, My suggestions will relate parts rather than procedures:- If you aren’t buying genuine VAG parts at discount, then I would suggest you buy Gates kits which will include belt, tensioner and water pump (if belt driven). As Kev says, eBay would be one source, but if I was in your situation, I would want to ensure that what you buy off eBay is not ‘old stock’ , since belts should be renewed every five years, and you could find belts may already be a couple or 3 years old before they are even fitted! I have used Car Parts in Motion to good effect and at reasonable prices, so it might be worth checking there. I would also renew the serpentine belt and tensioner at the same time. Hope some of this helps. Kind regards, Gareth. 1
runman99 Posted June 22, 2022 Author Posted June 22, 2022 13 hours ago, Magnet said: Hello Mathew, My suggestions will relate parts rather than procedures:- If you aren’t buying genuine VAG at discount, then I would suggest you buy Gates kits which will include belt, tensioner and water pump (if belt driven). As Kev says, EBay would be one source, but if I was in your situation, I would want to ensure that what you buy off EBay is not ‘old stock’ , since belts should be renewed every five years, and you could find belts may already be a couple or 3 years old before they are even fitted! I have used Car Parts in Motion to good effect and has reasonable prices, so might be worth checking there. I would also renew the serpentine belt and tensioner at the same time. Hope some of this helps. Kind regards, Gareth. Thanks for that Gareth. I will have a look . Cheers. 🙂
Magnet Posted June 22, 2022 Posted June 22, 2022 Again, Gates belt and tensioner should be available Mathew. Kind regards, Gareth.
