Asad Posted June 23, 2022 Share Posted June 23, 2022 Hi my A6 C7 2012 s line (engine CGLC) DPF has had a slight crack and I had it welded and It seemed to be fine for like 2 days and now the smoke seems to come out of the ring. I have attached a video so you can see it. I do not have a problem with power, MPG, speed, idle no lights on the dash car works fine but slight smoke comes out that's the only problem. did an emissions test and that was fine too. could this be a bigger problem? Do you think the ring needs some sort of seal on it as when it was welded it was not put back together properly? or needs to be welded again? The ring am talking about is what am touching and when I poke it, it does more back and my finger slightly can slide through. Thanks WhatsApp Video 2022-06-23 at 7.00.42 PM.mp4 Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted June 24, 2022 Share Posted June 24, 2022 20 hours ago, Asad said: Hi my A6 C7 2012 s line (engine CGLC) DPF has had a slight crack and I had it welded and It seemed to be fine for like 2 days and now the smoke seems to come out of the ring. I have attached a video so you can see it. I do not have a problem with power, MPG, speed, idle no lights on the dash car works fine but slight smoke comes out that's the only problem. did an emissions test and that was fine too. could this be a bigger problem? Do you think the ring needs some sort of seal on it as when it was welded it was not put back together properly? or needs to be welded again? The ring am talking about is what am touching and when I poke it, it does more back and my finger slightly can slide through. Thanks WhatsApp Video 2022-06-23 at 7.00.42 PM.mp4 Hi it needs rewelding by a specialist as the two parts are very different the DPF I am guessing is pre formed stainless and the bit at the end is some sort of cast steel /iron which will require a specialist welding to get it back to factory. Steve. Quote Link to comment Share on other sites More sharing options...
Asad Posted June 24, 2022 Author Share Posted June 24, 2022 (edited) Hi thanks for the reply. Is it possible to use exhaust putty and apply it then apply a DPF clamp on top of it? Edited June 24, 2022 by Asad Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 25, 2022 Share Posted June 25, 2022 I would say not, it'll need welding or replacing. 1 Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted June 25, 2022 Share Posted June 25, 2022 19 hours ago, Asad said: Hi thanks for the reply. Is it possible to use exhaust putty and apply it then apply a DPF clamp on top of it? Hi if the putty gets into the DPF even a small amount it will go into super heat and blow a hole in the DPF core. Steve. Quote Link to comment Share on other sites More sharing options...
coupe4 Posted June 26, 2022 Share Posted June 26, 2022 Thats sound advice steve,that happened to a friend of mine with an a4 and the putty destroyed the dpf.it turned into an expensive job then.greg 1 Quote Link to comment Share on other sites More sharing options...
