Mark609027 Posted June 27, 2022 Posted June 27, 2022 59 plate a3 convertible 2l diesel driving down road starts holding back then cuts out after which it won't start just turns over not firing just spinning over anyone got any ideas
Stevey Y Posted June 27, 2022 Posted June 27, 2022 2 hours ago, Mark609027 said: 59 plate a3 convertible 2l diesel driving down road starts holding back then cuts out after which it won't start just turns over not firing just spinning over anyone got any ideas Hi get the car diagnosed with a scanner the code that comes up will give you a clue to whats failing, wild guess is its a fuelling problem possibly the lift pump in the tank. Steve.
Mark609027 Posted June 27, 2022 Author Posted June 27, 2022 Yeah checked with diagnostic no fault found apart from passenger door lock!
geoffrey Posted June 29, 2022 Posted June 29, 2022 Hi Mark, no fault found ? door lock not a fault? did you clear /repair the door lock ? detailed feedback would be most helpful to the forum. Regards Ken
cliffcoggin Posted June 29, 2022 Posted June 29, 2022 On 6/27/2022 at 10:06 PM, Mark609027 said: Yeah checked with diagnostic no fault found apart from passenger door lock! Unless that was a professional grade scanner it can not be relied upon. The cheap scanners from China are cheap for a reason.
