Phil ako Posted June 29, 2022 Share Posted June 29, 2022 Hi all I have an audi a4sline cabriolet. I have had a flat battery and my key wont work in boot. I started removing back seat to get in but I am now stuck. I cannot get the backrest off. There are only 2 seats to th rear and headrests are fixed Any ideas pls Cheers Phil Quote Link to comment Share on other sites More sharing options...
JMKC82 Posted June 29, 2022 Share Posted June 29, 2022 Hi Phil, Sorry if this is stupid, key worked in your door? But not in the boot, strange. WD-40 in the lock? Or is the mechanism seized? Get a charger and charge the battery? Then use the remote? Ripping out the seats sounds a bit extreme. Why do you need to get into the boot? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Phil ako Posted June 29, 2022 Author Share Posted June 29, 2022 46 minutes ago, JMKC82 said: Hi Phil, Sorry if this is stupid, key worked in your door? But not in the boot, strange. WD-40 in the lock? Or is the mechanism seized? Get a charger and charge the battery? Then use the remote? Ripping out the seats sounds a bit extreme. Why do you need to get into the boot? Thanks, Joe The battery is in the boot joe Quote Link to comment Share on other sites More sharing options...
Steve Q Posted July 2, 2022 Share Posted July 2, 2022 This link should help: Quote Link to comment Share on other sites More sharing options...
JMKC82 Posted July 7, 2022 Share Posted July 7, 2022 On 6/29/2022 at 4:43 PM, Phil ako said: The battery is in the boot joe jump / charging points under the bonnet. Thanks, Quote Link to comment Share on other sites More sharing options...
Phil ako Posted July 7, 2022 Author Share Posted July 7, 2022 Many thanks gents I would never have guessed Cheers Phil Quote Link to comment Share on other sites More sharing options...
