Hi guys,
Is anyone able to identify the part and part number for the door pull I’ve pointed the red arrow at?
Struggling to find an exploded diagram online or potential replacement.
When I pulled to close the door yesterday, it came loose at the top (yellow circle) and I believe it is damaged.
I'm considering drilling a hole and fixing it with a nut/bolt and washer on the inside of the door card.
Thanks in advance!
I don't know the part number, but I do know a new one will be expensive. Have you considered a secondhand part from a car breaker? Many breakers are online nowadays and will post the part to you.
Thanks Cliff - I always consider breakers first haha!
I will likely try to repair first but if I completely break it then I’m hoping for a part number or at least Part name to help me search 😁
