My a4 b8 avant goes into limp mode at 2100 rpm, the glow plug light flashes and occasionally the engine management light comes on also. Diagnostic shows underboost fault.
It always resets after restarting the engine.
Is this terminal turbo signs or perhaps just a boost sensor?
Help gratefully received!
Expand
FAULT CODE -0299-(Turbo underboost)
Kicks in @ 2100rpm -3000rpm
Power reduction and glow plug lamp flashes
Condition usually resets upon ignition reset..
Sometimes needs OBD to perform fault reset.
POSSIBLE BOOST SENSOR? or TURBO FAULTY?
  On 7/12/2022 at 11:08 AM, Steve Q said:
Could be a leaking pipe. Worth considering before changing the turbo.
Expand
Thanks sir..I appreciate your input. I will investigate that forthwith. 🙂
