DPF filter how often should you regenerate at what speed in what gear and what rpm and for how many miles thanks for helping the car is anAudi A3 TDI Cabriolet.
Expand
Hi you can't force the car to regenerate unless its done via a scanner the car will do it of its own volition when the ECU notes the soot levels are above normal, when it starts just take the car for a drive for at least five miles until the cycle finishes, if you use a proprietary DPF additive with every third tank of fuel this cuts down on the regeneration time as it makes the soot particles smaller therefore they burn off quicker even during town driving.
Thanks Steve as for past problems all sorted hopefully didn’t need reprogramming but luckily we were recommended to Audi Central Birmingham who are excellent they have same equipment as Audi
Expand
Thanks Steve car running really well thanks to Audi Central and the best car dealer you could meet he’s met all costs …
What would you suggest to clean the aluminium surround to the screen and hood as it looks a little pitted
