I used to be able to be able to click on the VCDS emblem in the left top corner and make the screen bigger.
This no longer works, WHY ?
It is so difficult to see the small screen.  AAAAG 😡
hi roy,i only purchased mine 3 months ago and only ever had the small screen option but your right as i remember seeing it on a pals full screen so maybe theres a way to change it.some one on here might have a solution as id like to have the full screen too.
The size option is stil there but it has been greyed out so that it does not work.
If i remember correctly, it was a sod to reduce it if you went too big.
I found this  -
[Options] -> Click on the User Interface and Identification tab. Change Window size from 10 to something larger. Do it incrementally in small steps until you get a feel for what works on your display.
thanks roy im brutal with computers but ill get my son [who knows everything!!!] to give it a shot.
I wanted to know how to do it myself and accidentally came across the answer while browsing around..
