Corrie Posted July 25, 2022 Posted July 25, 2022 My neighbour, who's a mechanic, thinks I have a tiny fuel leak in the common rail switch in my 2012 a3. I tend to get a smell.of fuel when I start the car up, and it's quite noticeable when I've come off the motorway. Is this a fix I can do, or is it a job for a mechanic?
Stevey Y Posted July 25, 2022 Posted July 25, 2022 1 hour ago, Corrie said: My neighbour, who's a mechanic, thinks I have a tiny fuel leak in the common rail switch in my 2012 a3. I tend to get a smell.of fuel when I start the car up, and it's quite noticeable when I've come off the motorway. Is this a fix I can do, or is it a job for a mechanic? Hi if its the metering solenoid or the pressure solenoid both are pretty easy to change about fifteen mins if you take your time, just don't over tighten the new one and obviously only change the one thats wet, whilst in there check the connector pipes to the injectors in case its one of them weeping. Steve. 1
RoyC Posted July 25, 2022 Posted July 25, 2022 A few videos here https://www.youtube.com/results?search_query=Common+rail+switch+LEAK 1 1
cliffcoggin Posted July 25, 2022 Posted July 25, 2022 Surely the mechanic neighbour who found the leak can also advise on its repair?
Corrie Posted July 25, 2022 Author Posted July 25, 2022 17 minutes ago, cliffcoggin said: Surely the mechanic neighbour who found the leak can also advise on its repair? He just advised to get it checked when I take it into my usual mechanic. I don't like to bother the man too much when he's at home 1
RoyC Posted July 26, 2022 Posted July 26, 2022 12 hours ago, Corrie said: I don't like to bother the man too much when he's at home I am the same. My son works in an accident repair shop and he don't want to do the same thing in his down time. 2
Stevey Y Posted July 26, 2022 Posted July 26, 2022 21 hours ago, Corrie said: He just advised to get it checked when I take it into my usual mechanic. I don't like to bother the man too much when he's at home Thats the right attitude as if you badger the man at home its likely to get the wrong response. 1
