A4 Avant B8.5,2012,105kW,2.0 TDI, 200000km
Marko C94
Hello guys,
I know there is a very slim chance of finding the root cause of this shaking on forum, but maybe someone managed to solve this issue. First of all, car is super reliable ,extremly well maintained and I'm super happy with it. But this is starting to really frustrate me. I have been to two really proffesional vag specialists and they couldnt find anything. Car is currently on 200003km, shaking started at around 170000km.. shaking comes only when accelarating, it goes through the car, and is stronger when you accelerate from low rpms.. shaking is also stronger in higher gear(accelerating in6th gear from low rpm is strongest, gear lever goes crazy)
So far changed inner and outer cvs, both driveshafts(all original parts), engine mounts , and my flywheel and clutch are in very good condition(there is absolutly no sound whatsoever).. there in no misfire, i even had.my gearbox opened and all joints look factory new.. i have a feeling this is something bizzare , and yet i cant figure out what it is..
17 minutes ago, Stevey Y said:
Hi also known as a
Hi also known as a crankshaft pulley.
Thank you for the reply? How can i test if it is really crankshaft pulley, and is that problem something common in 2.0TDI?
Hi with that sort of milage it should have been changed about 100k ago, there is no way of testing them other than with a crowbar underneath them to see if it moves up and down but considering the price of a new one just changing it would be better policy, the outer ring of the pulley is bonded to the inner with high shore rubber which when it deteriorates allows movement/vibration, the DMF and crank damper are there to stop harmonic resonance which occurs around 1800-2000 rpm.
Thank you steve, i have oil and filter change next week so will change balancer too.. i will post back here if that solved the issue, maybe it will be useful to someone!
  • Thanks 1
  • 3 weeks later...
