JMc Posted July 30, 2022 Share Posted July 30, 2022 Both front and rear washers have stopped working on my 2018 A3. I hear no whirring of the pump. My first step before dismantling anything would be to check the fuse. I've looked in the Audi Owner's Manual that came with the car but there appears to be no listing for a washer pump fuse. I've spent hours now on Google looking for threads and openning up fuse box diagrams but to no avail. It is listed on earlier models but not the 8V. I do note that I have Fuse 20 present in the Engine Bay and it isn't listed in the Owner's Handbook, but that may be a red herring as I see it shown as a second Horn fuse on some of the online diagrams. I'm hoping I can avoid delving into the void behind the bumper to fix this! Any help to locate the right fuse would be welcome. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted July 30, 2022 Share Posted July 30, 2022 Ha e you looked at this: https://www.google.com/amp/s/fuse-box.info/audi/audi-a3-s3-8v-2013-2018-fuses Should be F43. Quote Link to comment Share on other sites More sharing options...
JMc Posted July 30, 2022 Author Share Posted July 30, 2022 16 minutes ago, Steve Q said: Ha e you looked at this: https://www.google.com/amp/s/fuse-box.info/audi/audi-a3-s3-8v-2013-2018-fuses Should be F43. Thanks Steve, you're right that the top diagram for the 2013 model shows F43 as washers. However, there are 4 versions by year shown there and it's the last one Assignment of the fuses in the Instrument panel (2017, 2018, 2019) that applies to my car. That shows F43 as Sound Amplifier and it is also physically absent from the fuse box. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted July 30, 2022 Share Posted July 30, 2022 Ah, my only other advice would be to ring an Audi parts department as theyll have a schematic. Quote Link to comment Share on other sites More sharing options...
JMc Posted July 30, 2022 Author Share Posted July 30, 2022 3 minutes ago, Steve Q said: Ah, my only other advice would be to ring an Audi parts department as theyll have a schematic. Ta Quote Link to comment Share on other sites More sharing options...
M.smities Posted December 30, 2022 Share Posted December 30, 2022 Hi John I have same problem with front washers not working did it you find out what fuse to Check ? Mine is a 2016 model A3 1.4 and I too can’t find a fuse . Quote Link to comment Share on other sites More sharing options...
