4 month old A3 8y 35 tfsi saloon  wipers keep shuddering across windscreen when raining
dealer fitted new wiper blades but driving in rain last week still doing it ?
Try claybaring your windscreen to get rid of all the MUCK and diesel fumes.
Also wipe your blades with carb cleaner.
  On 8/6/2022 at 4:48 PM, RoyC said:
Try claybaring your windscreen to get rid of all the crap and diesel fumes.
Expand
Hi be very careful as the description Cr@p might offend the automatic insult monitor, example I put in a post the opposite of advance and it removed that as being derogatory. Oh what wonderful world we live in where you can't call a spade, a spade.
  • Haha 1
Hello Mick,
The windscreen needs a thorough clean. You could try some washing powder sprinkled onto a wet windscreen and rubbing this in gently with a cloth, before hosing it off again. I follow this with a good wiping with meths ( personally I would not use carb.  cleaner since it contains acetone, which will attack the rubber).
Also wipe the blade edges with meths, and follow this procedure with a good wiping with windscreen washer fluid.
We take it you are using the correct concentration of washer fluid.
