Corrie Posted August 12, 2022 Posted August 12, 2022 (edited) My car has started to over rev when Im trying to accelerate up any incline. The display starts showing lower gears and jumps about. Looking online it seems to be the gearbox ecu but thought I'd ask you lovely people in my phone Regards Edited August 12, 2022 by Corrie
cliffcoggin Posted August 12, 2022 Posted August 12, 2022 Please confirm you are using an automatic gearbox. 1
Corrie Posted August 12, 2022 Author Posted August 12, 2022 On 8/12/2022 at 8:51 AM, cliffcoggin said: Please confirm you are using an automatic gearbox. Expand Sorry, it's 6 speed manual
cliffcoggin Posted August 12, 2022 Posted August 12, 2022 I am not sure I fully understand the problem. Does the engine speed, as shown by the tachometer, truly go up and down, or is it just the indicator lights that are changing?
Magnet Posted August 13, 2022 Posted August 13, 2022 Classic clutch slip? - based on description given. Kind regards, Gareth. 1
Corrie Posted August 13, 2022 Author Posted August 13, 2022 On 8/12/2022 at 5:43 PM, cliffcoggin said: I am not sure I fully understand the problem. Does the engine speed, as shown by the tachometer, truly go up and down, or is it just the indicator lights that are changing? Expand The rev counter goes up but the speed doesn't. The speed display on the dash jumps about and doesn't seem to know what gear it's in.
Magnet Posted August 13, 2022 Posted August 13, 2022 Many thanks Corrina, So the car is a ‘fully, uncomplicated 6 speed manual’ -? If so, the rev. counter increasing without the speed increasing can be understood by my suggestion of what may be wrong. The speedo jumping around?? One simple test you could do:- Put the car in 4th gear on level ground with handbrake off, and attempt to move off in that gear - exactly as you would do in 1st gear. The engine should stall quite quickly as the drive gets taken up. Does it? Kind regards, Gareth.
cliffcoggin Posted August 13, 2022 Posted August 13, 2022 On 8/13/2022 at 9:26 AM, Corrie said: The rev counter goes up but the speed doesn't. The speed display on the dash jumps about and doesn't seem to know what gear it's in. Expand Sounds like the clutch is slipping.
Corrie Posted August 13, 2022 Author Posted August 13, 2022 On 8/13/2022 at 10:16 AM, Magnet said: Many thanks Corrina, So the car is a ‘fully, uncomplicated 6 speed manual’ -? If so, the rev. counter increasing without the speed increasing can be understood by my suggestion of what may be wrong. The speedo jumping around?? One simple test you could do:- Put the car in 4th gear on level ground with handbrake off, and attempt to move off in that gear - exactly as you would do in 1st gear. The engine should stall quite quickly as the drive gets taken up. Does it? Kind regards, Gareth. Expand The speedo revs towards the red with no increase in speed. It's a normal 6 speed gear box. I'll try doing the 4th gear test and will let you know 1
cliffcoggin Posted August 13, 2022 Posted August 13, 2022 Another test is to find the "bite point" of the clutch. Apply the handbrake firmly, press the clutch pedal to the floor, engage first gear, open the throttle a little (1300 rpm approx,) and slowly raise the clutch pedal, noting the pedal height at which you can feel the clutch start to engage. That height should be around half up. If that bite point is much above half way there is something wrong with the clutch.
Corrie Posted August 13, 2022 Author Posted August 13, 2022 On 8/13/2022 at 1:22 PM, cliffcoggin said: Another test is to find the "bite point" of the clutch. Apply the handbrake firmly, press the clutch pedal to the floor, engage first gear, open the throttle a little (1300 rpm approx,) and slowly raise the clutch pedal, noting the pedal height at which you can feel the clutch start to engage. That height should be around half up. If that bite point is much above half way there is something wrong with the clutch. Expand The bite point is almost at the top
cliffcoggin Posted August 13, 2022 Posted August 13, 2022 That confims the clutch is slipping. If you are lucky it may just be a matter of adjustment; if you are unlucky you need a new clutch.
Magnet Posted August 23, 2022 Posted August 23, 2022 Hello Corina, Tidying up some loose ends, and wondering where you are with this now. Kind regards, Gareth.
Corrie Posted August 23, 2022 Author Posted August 23, 2022 On 8/23/2022 at 2:50 PM, Magnet said: Hello Corina, Tidying up some loose ends, and wondering where you are with this now. Kind regards, Gareth. Expand Hi, sorry for the late update. The clutch has definitely gone and is now with the mechanic to have a new one fitted
Magnet Posted August 24, 2022 Posted August 24, 2022 Hello Carrie, Many thanks. Make of parts he is using? Kind regards, Gareth.
Corrie Posted August 24, 2022 Author Posted August 24, 2022 On 8/24/2022 at 6:01 AM, Magnet said: Hello Carrie, Many thanks. Make of parts he is using? Kind regards, Gareth. Expand I have no idea lol I just leave the car with him and he does the rest (I trust him implicitly with my cars)
Magnet Posted August 25, 2022 Posted August 25, 2022 That’s fine if you are happy, but there are some pretty dodgy aftermarket clutches about. I could have advised you what to go for if interested. Kind regards, Gareth.
Corrie Posted August 25, 2022 Author Posted August 25, 2022 On 8/25/2022 at 5:29 AM, Magnet said: That’s fine if you are happy, but there are some pretty dodgy aftermarket clutches about. I could have advised you what to go for if interested. Kind regards, Gareth. Expand Thankyou for the offer, at least I know where to come. The clutch comes with a 2 year warranty and I know the guy I use would do the right thing
cliffcoggin Posted August 27, 2022 Posted August 27, 2022 Can we presume the lack of any news indicates the new clutch has solved the problem?
