Can you get DPF remap delete without actually removing the DPF or do both need done
I can't see how you can delete a DPF without removing it
No I’ve just had mine done dpf had to be cut out and egr blanked off
It technically is an MOT failure if you remove dpf. Even though I can understand why youre thinking of it.
https://www.gov.uk/government/news/new-rules-for-mot-to-test-for-diesel-particulate-filter
The vehicle will automatically fail the MOT test if the filter had been fitted as standard but is found to be no longer present.
