Gerry TT Posted August 29, 2022 Posted August 29, 2022 Hi We are looking for a nice 07-08 3.2 V6 convertible, ideally with the Big screen for radio etc. and magnetic option. Got up to 7k to spend for the right car. We are ready to press the button.
Steve Q Posted August 29, 2022 Posted August 29, 2022 Sounds like you've got a good plan. Bare in mind the magnetic shocks are expensive to replace and have to be coded to the car. Also make sure the car has had all required services. Manual gearbox is allegedly sealed for life which is nonsense as the seals fail. Also make sure quattro system works and has been serviced. Check tyres have even wear as uneven emerald can damage the quattro system. they're lovely cars my mate has the hard top. 1
Gerry TT Posted August 29, 2022 Author Posted August 29, 2022 1 hour ago, Steve Q said: Sounds like you've got a good plan. Bare in mind the magnetic shocks are expensive to replace and have to be coded to the car. Also make sure the car has had all required services. Manual gearbox is allegedly sealed for life which is nonsense as the seals fail. Also make sure quattro system works and has been serviced. Check tyres have even wear as uneven emerald can damage the quattro system. they're lovely cars my mate has the hard top. Yes sorry should had said only interested in the S-Tronic.
Steve Q Posted August 29, 2022 Posted August 29, 2022 1 minute ago, Gerry TT said: Yes sorry should had said only interested in the S-Tronic. No probs. Still just as important it's been serviced. Degrading oil can affect gear changes. To the point the s tronic can refuse to go into reverse for example. 1
