alerton Posted August 30, 2022 Posted August 30, 2022 Hi, i recently got my 2006 a4 convertible 3.0tdi, it had a few issues that i knew about which i have worked my way through, (roof motor, various broken wires in boot and missing trim etc) but the problem i was not aware of is the engine cutting out. not all the time, 95% the time its fine, starts first time every time and runs great but just sometimes when you give it a good bit of throttle it just cuts out, no cough, no stutter just dies. it starts straight back up fine then runs ok for days again. when it happens there is no warning, no engine management lights, nothing, i assumed there would be error codes to point me towards what is causing it but no codes to read at all so im confused and out of ideas. first i though turbo over boost, then fuel pressure or maybe even blocked fuel filter (changed that anyway recently) but id expect all those would create an error code. has anyone had a similar problem or any ideas please?
Steve Q Posted August 31, 2022 Posted August 31, 2022 Could it be the MAF sensor? Or an imobilser fault?
alerton Posted August 31, 2022 Author Posted August 31, 2022 44 minutes ago, Steve Q said: Could it be the MAF sensor? Or an imobilser fault? could be but if it were immobiliser id expect that to be more 'random' rather than just under heavy acceleration ? possibly MAF but wouldn't that normally give a fault code ?
Steve Q Posted August 31, 2022 Posted August 31, 2022 Good point and yes MAF would normally through a fault. Could it be an issue with.the fuel pump is it's getting starved of fuel? Gunged up?
alerton Posted August 31, 2022 Author Posted August 31, 2022 1 hour ago, Steve Q said: Good point and yes MAF would normally through a fault. Could it be an issue with.the fuel pump is it's getting starved of fuel? Gunged up? could be but again id expect that to give a low fuel pleasure fault code but thanks for the suggestions
alerton Posted November 20, 2023 Author Posted November 20, 2023 2 hours ago, Con92 said: Did you ever solve this problem? no, i changed the HP fuel pump, the tank sender pump, fuel filter, had the injectors pressure tested nothing solved the problem, in the end i put it down to the car having a dodgy re-map from before i owned it. then a hit / run driver in a stolen car solved the issue for good lol.
NIck8855 Posted April 4, 2024 Posted April 4, 2024 Hi , have audi a6 3.0tdi quattro 2005 . When you drive and touching acceleration pedal is all ok . but when you stop anywhere engine cuts off . No error codes . I change flow sensor , oil pressor sensor , new fuel filter . Some days drives ok . but most days cuts off . Any suggestions ? Tnx
Steve Q Posted April 4, 2024 Posted April 4, 2024 9 minutes ago, NIck8855 said: Hi , have audi a6 3.0tdi quattro 2005 . When you drive and touching acceleration pedal is all ok . but when you stop anywhere engine cuts off . No error codes . I change flow sensor , oil pressor sensor , new fuel filter . Some days drives ok . but most days cuts off . Any suggestions ? Tnx Could it be an issue with the high pressure fuel pump?
