ccfc skyblues Posted September 1, 2022 Share Posted September 1, 2022 Hi guys please could you advise I have has the following problem with my Audi A3, 2015 TDI coil flash comes on after about 50 mins of continuous driving. when I plug in old reader I get the following message charge air cooler pressure sensor circuit low, bank 1. I have changed the sensor with a genuine one. still no luck, I have changed the lambda exhaust sensor bank 1, still no luck, I have change all the glow plugs including the one with the sensor still no luck. I recently changed the sensor with a friends car still no luck .I have added dpf cleaner put a few tanks of shell diesel premium fuel no luck. I assume its a wiring issue. how do I check this. engine management light comes on but car does not go in limp mode. I clear the code as soon as I drive 50 mins it comes on. if turn the ignition on and off a few times it goes away only to come back on. Thanks Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted September 1, 2022 Share Posted September 1, 2022 I would not place much reliance on the code reader unless it is a professional grade. The cheap readers often give misleading results causing owners to waste money on uneccesary and expensive parts. I suggest you get a professional diagnosis before spending any more money. Before you do even that, tell us how old the battery is. Quote Link to comment Share on other sites More sharing options...
