Posted (edited)
Hi all,
I’m looking at getting an S3 8P and have done a bit of research on the faults etc… what are the faults to look for that would be a ‘walk away’, also what common problems are simple fixes and nothing to stress about?
Also as most are getting on in miles a new clutch is probably not far away, what would be a good clutch to go for when the time comes?
Edited by RB8694
I'd recommend you look at buyers guides on YouTube.
Check service history, has the Cambelt and water pump been changed on time as this will cost you £500-600. If an auto has the gearbox oil been changed on time as old oil can affect the b's tronic gearbox from changing gear properly.
Are all tyres matching on the same axle as uneven tyre brands or wear can affect and damage the quattro system. Has the quattro system been serviced?
Does the AC work? If not and it's the compressor this can be a £1000 job.
If xenon lights do they work properly?
And do all other electrical systems and items work?
