Can anyone help with the correct OEM part number for a 2016 A5 B8 1.8 petrol s-line cabriolet special edition + tfsi
the part fitted at present is 8K 0959633B. I am told that it should be 0959633F. The module is causing severe battery drain and needs replacing.
Usually the last letter is an upgraded and most up to date part. I'd definitely recommend speaking to Audi regarding compatibility
