Astro25 Posted September 12, 2022 Posted September 12, 2022 Hi Guys First post so be gentle... Ive recently bought a 2007 Tdi 170 S line and have noticed sometimes its a little tricky getting into first, but fine if i go second and then into first, so thinking alignment maybe,. Ive read on a google search that there is a linkage on top that wears and can cause this... Is that the most likely as there quite a bit of movement on the stick itself.. If so, any ideas where i can get one, some said to put a short shift on instead as it helps.. Thanks in advance
Astro25 Posted September 12, 2022 Author Posted September 12, 2022 Thanks Steve, at least it sounds like a quick fix
Steve Q Posted September 13, 2022 Posted September 13, 2022 6 hours ago, Astro25 said: Thanks Steve, at least it sounds like a quick fix Yea it's more straightforward
cliffcoggin Posted September 13, 2022 Posted September 13, 2022 A worn clutch can cause similar gear selection problems. Does the clutch work as it should? Do you get any clutch slip under load?
Astro25 Posted September 13, 2022 Author Posted September 13, 2022 9 hours ago, cliffcoggin said: A worn clutch can cause similar gear selection problems. Does the clutch work as it should? Do you get any clutch slip under load? Clutch seems fine, not slipping and goes into all the gears quite smoothly. Feels more like it’s hitting the side of a slot, like not quite going in properly if that makes any sense
cliffcoggin Posted September 14, 2022 Posted September 14, 2022 In that case I'd agree it's worn linkage.
Astro25 Posted September 14, 2022 Author Posted September 14, 2022 On 9/13/2022 at 5:34 AM, Steve Q said: Yea it's more straightforward Is it basically a case of fitting the quick shifter mod on the gearbox end of the cables or a new shifter assembly too
Astro25 Posted September 15, 2022 Author Posted September 15, 2022 Is this what I need?? https://www.ebay.co.uk/itm/171462640219
