arron1995 Posted September 13, 2022 Posted September 13, 2022 as the title says, when im driving a long and it doesnt matter what gear/speed im doing, when i let off the throttle the rpm needle jumps around and its quite annoying, has anyone had this issue and what was the cause, thanks. car is a manual and its been smoke tested and nothing found leak wise.
cliffcoggin Posted September 14, 2022 Posted September 14, 2022 Does the engine speed also go up and down, or is it just the tachometer reading that changes while the engine speed is constant? Is this the same jalopy you asked about in June and failed to inform us of the outcome?
Steve Q Posted September 17, 2022 Posted September 17, 2022 I'd recommend a diagnostic check to see if any fault codes flag up. Worth getting the MAF and lambda sensor looked at.
arron1995 Posted September 17, 2022 Author Posted September 17, 2022 On 9/17/2022 at 5:05 PM, Steve Q said: I'd recommend a diagnostic check to see if any fault codes flag up. Worth getting the MAF and lambda sensor looked at. Expand absolutely no fault codes mate, i did have a vacuum leak caused by the downpipe which was fixed, maf is fine, lambda sensors havent been looked at though i dont think.
arron1995 Posted September 17, 2022 Author Posted September 17, 2022 On 9/14/2022 at 8:27 AM, cliffcoggin said: Does the engine speed also go up and down, or is it just the tachometer reading that changes while the engine speed is constant? Is this the same jalopy you asked about in June and failed to inform us of the outcome? Expand sorry mate i thought i had replied, this is a different car, only the rpm needle flickers.
Steve Q Posted September 18, 2022 Posted September 18, 2022 When you say the needle flickers is it just the needle or is the engine revs definitely off.
arron1995 Posted September 18, 2022 Author Posted September 18, 2022 On 9/18/2022 at 4:10 AM, Steve Q said: When you say the needle flickers is it just the needle or is the engine revs definitely off. Expand Literally il let off the throttle or when I blip when I’m driving the rpm needle will flicker, it doesn’t do this if I am stationary and rev, only when driving. It also happens when I am driving downhill without touching the clutch or accelerator. My rocker cover gasket is leaking but dno if that will have any affect on this scenario.
arron1995 Posted September 18, 2022 Author Posted September 18, 2022 On 9/18/2022 at 6:38 PM, Steve Q said: Could it be clutch related? Expand i was thinking this but it was mapped recently by r-tech and they said my clutch was spot on. someone mentioned something about a clutch switch to me.
Steve Q Posted September 21, 2022 Posted September 21, 2022 On 9/18/2022 at 7:02 PM, arron1995 said: i was thinking this but it was mapped recently by r-tech and they said my clutch was spot on. someone mentioned something about a clutch switch to me. Expand Could be the switch. Was it doing it prior to the remap?
arron1995 Posted October 24, 2022 Author Posted October 24, 2022 On 9/21/2022 at 6:28 AM, Steve Q said: Could be the switch. Was it doing it prior to the remap? Expand sorry for the late reply steve, its done it since i bought it, so prior to the map.
Steve Q Posted October 25, 2022 Posted October 25, 2022 I'd definitely look at getting the switch looked at.
