gaz1234 Posted September 24, 2022 Posted September 24, 2022 Hello going to look at an Audi tomorrow that had the following advisories. How much would these bits cost to replace? Monitor and repair if necessary (advisories): Offside Front Inner Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i)) Offside Front Shock absorbers has light misting of oil (5.3.2 (b)) Offside Rear Coil spring corroded (5.3.1 (b) (i)) cheers
Magnet Posted September 24, 2022 Posted September 24, 2022 Hello Gary, Your best bet is to ring a local independent and ask for prices for:- Supply and fit off side suspension wishbone. Supply and fit pair of front shock absorbers. (would not advise to just change one). Rear spring corroded ? Depends how badly, and again change as pair. What is the service history like on the vehicle? Are you buying locally? If not, consider the impracticality of getting any warranty work done. Last V5 issue date? ( available on DVLA Vehicle check). This should indicate how long the last owner has owned it. Short length ownership would be iffy. Kind regards, Gareth.
gaz1234 Posted September 25, 2022 Author Posted September 25, 2022 Hi gareth car bought. Drive nice. Been looked after. Lots of history. Will speak to my garage about the costs. i thought all s lines had cruise control but this looks not to have it
Magnet Posted September 26, 2022 Posted September 26, 2022 Great Gary, What about the fixing costs for the advisories that you enquired about? Kind regards, Gareth.
gaz1234 Posted September 26, 2022 Author Posted September 26, 2022 Will speak to my garage today. How does the servicing work on these? All on the computer and recorded online with Audi? There was no service book with it.
Magnet Posted September 26, 2022 Posted September 26, 2022 Hello Gary, Not quite sure what you mean by ‘how does the servicing work on these?’ Question:- when was the last recorded service , and what parts ( filters etc.) were changed then? What mileage has it done and what is your anticipated annual mileage? These answers will influence its service schedule going forward. Kind regards, Gareth.
gaz1234 Posted September 26, 2022 Author Posted September 26, 2022 In terms of there not being a book that’s stamped, so I presume it’s all online with Audi. i see according to the computer an oil change is due at 8k, but that’s it. my bmw shows when brakes, oil, mot on the i-drive. should I also contact Audi and get the details changed on the Audi for recalls etc? i presume they hold the service history too? Done 51k and last service was cam belt On 9/26/2022 at 11:17 AM, Magnet said: Hello Gary, Not quite sure what you mean by ‘how does the servicing work on these?’ Question:- when was the last recorded service , and what parts ( filters etc.) were changed then? What mileage has it done and what is your anticipated annual mileage? These answers will influence its service schedule going forward. Kind regards, Gareth. Expand
gaz1234 Posted September 26, 2022 Author Posted September 26, 2022 heres the history: 08/04/2014 - Delivery inspection 27/04/2015 - Flexible oil change service 21/04/2016 - Flexible oil change service 21/04/2017 - Service inspection and brake fluid change 24/04/2018 - Flexible oil change service 18/04/2019 - Flexible oil change service, both front tyres replaced with Pirelli tyres 26/04/2019 - Brake fluid service (Covid hit so service had to be delayed) 13/07/2021 - Brake fluid service and inspection with oil change 23/08/2021 - Replaced cambelt, replaced sump 08/04/2022 - Rear tyres replaced 05/08/2022 - Replaced nearside coil spring
Magnet Posted September 26, 2022 Posted September 26, 2022 Hello Gary, Many thanks, but you confuse me, and I’m well capable of confusion myself! The history is jibberish in my system. When you say ‘I presume it’s all online’ - yes it should be, and I thought you had confirmed a full service history before buying it, and would have requested print outs for your satisfaction. ’An oil change is due to 8k miles’ - does that mean in 8 K miles on from its current mileage? It will hopefully make sense when you present readable copy of the service history. Kind regards, Gareth.
