bootneck Posted October 14, 2022 Posted October 14, 2022 Lower front suspension arm Bush is worn, con I replace the bush.
Magnet Posted October 14, 2022 Posted October 14, 2022 Hello Bob, I guess you can just replace the bush, but why just the bush, rather than the less-work -more-comprehensive method of renewing the complete arm? Try pricing a Lemforder arm. Kind regards, Gareth.
Bigdave1230 Posted October 15, 2022 Posted October 15, 2022 Power flex sell the bushes separately but if your replacing either the arm or the bush and doing it yourself it’s worth getting a replacement bolt that goes through the rear bush as the bush sleeve and bolt corrode together resulting in the bolt not sliding out and needing heating or cutting out. The bolt has an elongated washer on it that adjusts for wheel alignment so needs marking up with tipex or similar otherwise it won’t drive properly after refitting.
bootneck Posted October 16, 2022 Author Posted October 16, 2022 Thanks for the info guys but I've recently been told that you can't replace the Bush. At a quandary now as what to do.
Magnet Posted October 16, 2022 Posted October 16, 2022 Well Bob, if you can’t replace the bush then you have to replace the arm.
