Brake fault warning light has appeared on dash. Audi A4 FTSI, 1.4
Have checked:
Brake Pads wear- OK.
Brake fluid level - OK.
I recently renewed brake sensor - working fine.
Any advice on problem would be appreciated.
Thank's in anticipation.
  On 10/16/2022 at 3:36 PM, Steve Q said:
Have you had a diagnostic check?
Expand
Thanks for your reply, Steve.
I have not had it tested as yet.I have ordered an OBD 11 diagnostic tester which I 'm hoping will highlight the fault code (Do you think it will)?
Thanks again.
Thanks again.
Expand
You're welcome. Yes it should show the fault code. Fingers crossed for you 🙂
