Teddynewson Posted October 16, 2022 Posted October 16, 2022 Valve stems are going on lovely not going the put the collars on yet as iv ordered and good few k44 from bg so I can clean the Valves and port holes lot af carbon there 20221016_120837.heicFetching info... 20221016_114527.heicFetching info... 20221016_115620.heicFetching info... 20221016_114554.heicFetching info... 20221016_114550.heicFetching info...
jdragon Posted October 16, 2022 Posted October 16, 2022 These posts are great, and I'm following with interest but I can't help think they should all be in the same thread 😄 1
Teddynewson Posted October 16, 2022 Author Posted October 16, 2022 On 10/16/2022 at 12:46 PM, jdragon said: These posts are great, and I'm following with interest but I can't help think they should all be in the same thread 😄 Expand Hi bud to be honest I thought it was at 1st as it kept coming up engine removal on the topic and when it didn't just thought I'd carry on this way
Teddynewson Posted October 17, 2022 Author Posted October 17, 2022 Not much done today removed 3 studs off the exhaust as thay snapped easy enough job and found a little bit of carbon cleaner so started on cleaning the valve still not finished but it's looking good
Teddynewson Posted October 19, 2022 Author Posted October 19, 2022 On 10/17/2022 at 11:09 AM, Teddynewson said: Not much done today removed 3 studs off the exhaust as thay snapped easy enough job and found a little bit of carbon cleaner so started on cleaning the valve still not finished but it's looking good Expand So come too a stop for the moment ordered so stuff wet and dry 800,1000,1500, another torque wrench as can't fined the small one and a full timing chain kit ouch
jdragon Posted October 20, 2022 Posted October 20, 2022 I think I've missed why you pulled the engine.
Teddynewson Posted March 3, 2023 Author Posted March 3, 2023 Haven't been on for abit due to work and other things so started on the valves clean and cutting back in new stems are on putting the keepers are a pain to put back on got 12 days off so should put a good dent in it and if all goes to plan engine should go back in 1
Steve Q Posted March 4, 2023 Posted March 4, 2023 Thanks for the update. Hope you make good progress over the next few days 🙂
Teddynewson Posted April 13, 2023 Author Posted April 13, 2023 On 3/4/2023 at 7:41 AM, Steve Q said: Thanks for the update. Hope you make good progress over the next few days 🙂 Expand Well its coming along nicely
Steve Q Posted April 14, 2023 Posted April 14, 2023 On 4/13/2023 at 9:11 PM, Teddynewson said: Well its coming along nicely Expand Wow, you've made great progress. I need my engine out yet lol 😆 2
Teddynewson Posted April 14, 2023 Author Posted April 14, 2023 On 4/14/2023 at 12:45 PM, Steve Q said: Wow, you've made great progress. I need my engine out yet lol 😆 Expand Its definitely a labour of love but she starting to look like a v8 now On 3/4/2023 at 7:41 AM, Steve Q said: Thanks for the update. Hope you make good progress over the next few days 🙂 Expand Well its coming along nicely
Teddynewson Posted April 14, 2023 Author Posted April 14, 2023 Cheers it's definitely a labour of love but she looking like a v8 now
Steve Q Posted April 14, 2023 Posted April 14, 2023 On 4/14/2023 at 1:00 PM, Teddynewson said: Cheers it's definitely a labour of love but she looking like a v8 now Expand Mines a labour of love too and sentimental. Just trying what the best option is to get mine mobile again.
Teddynewson Posted April 16, 2023 Author Posted April 16, 2023 On 4/14/2023 at 4:12 PM, Steve Q said: Mines a labour of love too and sentimental. Just trying what the best option is to get mine mobile again. Expand Why is your the same as mine valve stem seals gone Steve, the scary part was doing the head bolts and the 4 cam shaft adjusters on the torque setting especially the head as it was 30nm 60nm then 90 degree and a final 90 degree
Teddynewson Posted April 17, 2023 Author Posted April 17, 2023 Well the back plate on and new gasket what a pig too do and cleaned the valley and changed the gaskets in there
Teddynewson Posted April 17, 2023 Author Posted April 17, 2023 On 4/17/2023 at 12:53 PM, Teddynewson said: Well the back plate on and new gasket what a pig too do and cleaned the valley and changed the gaskets in there just opened the plenum up and may have found why it was smoking these should be sealed in place and thay wasn't so oil would have gone down the exhaust area Expand
Steve Q Posted April 17, 2023 Posted April 17, 2023 On 4/16/2023 at 11:17 AM, Teddynewson said: Why is your the same as mine valve stem seals gone Steve, the scary part was doing the head bolts and the 4 cam shaft adjusters on the torque setting especially the head as it was 30nm 60nm then 90 degree and a final 90 degree Expand My crank has gone on my 2.5tdi c5. So gotta decide whether I'm rebuilding the current engine or engine swap
Teddynewson Posted April 19, 2023 Author Posted April 19, 2023 On 4/17/2023 at 4:55 PM, Steve Q said: My crank has gone on my 2.5tdi c5. So gotta decide whether I'm rebuilding the current engine or engine swap Expand If the money right and a good engine do a swop, the do yours at your leisure bud
Teddynewson Posted April 19, 2023 Author Posted April 19, 2023 Well engine done for now and the plenum sorted just going too let everything settle but I'm happy and on the plus side nooo extra bolts haha
Steve Q Posted April 20, 2023 Posted April 20, 2023 On 4/19/2023 at 2:19 PM, Teddynewson said: If the money right and a good engine do a swop, the do yours at your leisure bud Expand Thank you. One garage said they've been struggling to source the parts. So might do a proper engine swap. You've made a great job with yours 🙂 1
Teddynewson Posted April 21, 2023 Author Posted April 21, 2023 Well she done just need to put it in the car now but do that on the next holiday
Teddynewson Posted April 22, 2023 Author Posted April 22, 2023 4 new vvt here and pcv Breather hose audi wanted 75.00, got for 25.00 new off eBay exactly the same not Chinese rubbish and 4 cam ajustets
Teddynewson Posted July 5, 2023 Author Posted July 5, 2023 Engine now finished and back in the car having a problem putting the cat on drivers side gearbox lowered, and subfram, seems very very tight and not much room
