peterb7 Posted October 17, 2022 Posted October 17, 2022 Been chasing a problem for months and I think I may have the answer finally. My fuel pressure from the tank dead headed is 3.5 to 4 psi using vag com in output mode to activate the pump. I do have etka and it does not state anywhere what the fuel pressure should be, only that it can be tested electrically by plugging a test switch into the fuse location. When I look for a replacement pump I get a choice of 0.5 bar or 5 bar. The engine runs well untill I demand more fuel, I have tested alot of components fitted a new turbo and actuator. any help would be appreciated.
Steve Q Posted October 22, 2022 Posted October 22, 2022 I'm guessing you've done a diagnostic check recently. Also I do think it could be the fuel pump. You could also looking at getting the tank cleaned maybe.
