Audi A5 B9 2.0 190
In the interest of sharing info (and to mitigate an AdBlue system related issue) I have been logging what VCDS tells me on some parameters.
My driving pattern is a 70 miles round trip for work (3 days/week) of A roads, and several 15-20 minute trips of again mostly A roads. We typically use my wife's car at weekend, otherwise I'll do another 60 miles round trip (minimum) drive on A roads.
My driving style to work is either conservative (avg. 57mph to get 76mpg+) or less patient where the economy drops to 64mpg. The shorter runs are less consistent 馃槂
I only use Esso or Shell fuel with a dose of either Archoil.
The data can be found in VCDS under: 01-Engine > Advanced Measuring Blocks > Look for 'red' values in the pop up menu
Thursday,04,August,2022,07:44:46:03341
Mileage: 121393km-75430miiles (approx)
聽 IDE03142 聽 Remaining vehicle distance until reducing agent deficiency 17701.75 km
聽 IDE03143-ENG57549 聽 Remaining engine starts until reducing agent deficiency-Bits 0-7 25聽
聽 IDE03144 聽 Used reducing agent since last service 161924.092 g
聽 IDE06254-ENG57549 聽 Status of a reducing agent warning-Bits 0-7 0聽
聽 IDE10031 聽 Sensor for reducing agent fill level: fill level height 163 mm
聽 IDE10032 聽 Reducing agent quality sensor: urea concentration 399.99 %
聽 IDE10039 聽 Reducing agent quality sensor: validity 1聽
聽 IDE10246 聽 Reducing agent tank volume: act. value filtered 19858 ml
聽 IDE10247 聽 Reducing agent tank volume: act. value calculated 20.17 l
聽 IDE10879 聽 Sensor for reducing agent fill level: calibrated 82.17 %
Sunday,14,August,2022,20:32:21:03341
Mileage: 121992km-75802mi
聽 IDE03142 聽 Remaining vehicle distance until reducing agent deficiency 17417.25 km
聽 IDE03144 聽 Used reducing agent since last service 162524.613 g
Tuesday,13,September,2022,18:43:22
Mileage: 123287km-76606mi 聽 Repair Order:聽
聽 IDE03142 聽 Remaining vehicle distance until reducing agent deficiency 16664.00 km
聽 IDE03144 聽 Used reducing agent since last service 163692.646 g
Saturday,08,October,2022,19:41:27
Mileage: 125263km-77835mi
聽 IDE03142 聽 Remaining vehicle distance until reducing agent deficiency 15622.00 km
聽 IDE03144 聽 Used reducing agent since last service 165575.847 g
Monday,17,October,2022,19:02:53
Mileage: 125481km-77970mi
聽 IDE03142 聽 Remaining vehicle distance until reducing agent deficiency 15335.75 km
聽 IDE03144 聽 Used reducing agent since last service 165753.154 g
聽 IDE10031 聽 Sensor for reducing agent fill level: fill level height 137 mm
聽 IDE10246 聽 Reducing agent tank volume: act. value filtered 17858 ml
聽 IDE10247 聽 Reducing agent tank volume: act. value calculated 17.80 l
聽 IDE10879 聽 Sensor for reducing agent fill level: calibrated 71.18 %
So for my vehicle, the AdBlue distance until deficiency drops at half the rate of actual mileage covered
I think I might do as others have suggested and ask the VAG specialist I go to for the next top up in approx. 14000k miles which will mean I shouldn't run it down the low low warning.
Open question:
How many miles/litre of AdBlue is everyone getting, and driving pattern?
5 hours ago, jdragon said:
Open question:
Hi I can't give any precise figures but I have to refill about every three months which equates to about 6000 miles, bearing in mind you use a lot more doing town work, its like the EGR valve which is open more when doing town work but hardly ever when out on a motorway.
Thanks for the info.
How many litres does your tank hold?
Hi at a rough guess about eleven litres goes down to 1500 miles when light comes on and takes at least seven or eight litres to fill back up.
  • 4 months later...
By my estimation I'm a couple of K miles away from needing to fill up the AdBlue tank.
I'm almost certain it has the 24 litre tank.
Where do you guys buy your AdBlue from? These seem like fairly common:
Carlube AdBlue 10L with spout : Amazon.co.uk: Automotive
Redex Adblue with Easy Pour Spout, Suitable for All Makes and Models, ISO22241 Compliant, 10 Litre : Amazon.co.uk: Automotive
Has anyone used a pump instead of the containers?
Hi about the best two are YARA from Halfords or Redex, cheaper at Tool station, the Yara is the best and Halfords are doing a deal at the moment three 3.5 litre pouches for 拢18.99.
  • Like 2
Nice one, thank you聽
  • 9 months later...
It looks like the YARA is discontinued at Halfords now. I used Redex this time. It's almost double the price of other brands like Greenchem and MANNOL聽
We use the one from Screwfix in the works minibus with no faults so far.聽
Hi Yara is not discontinued it just morphed into Halfords own brand, two 5ltr pouches for 拢20 the clue is on the packaging where it says made by YARA in small letters at the back of it with their viking logo.
  • Like 2
Thanks Steve. I've not seen this only ever browsing online, so I'm glad I posted what I thought 馃檭馃檪
