JimJnr72 Posted October 21, 2022 Posted October 21, 2022 A3 saloon 2015 1.6 Tdci ultra s line. Rear demister doesn鈥檛 work, and the radio reception is terrible. Checked fuse f7 and f53, and they are good. Rear demister button lights when pressed, but stays on constant. Can anyone help 馃檹
Steve Q Posted October 22, 2022 Posted October 22, 2022 On 10/21/2022 at 5:17 PM, JimJnr72 said: A3 saloon 2015 1.6 Tdci ultra s line. Rear demister doesn鈥檛 work, and the radio reception is terrible. Checked fuse f7 and f53, and they are good. Rear demister button lights when pressed, but stays on constant. Can anyone help 馃檹 Expand I'd recommend a diagnostic check to see if any fault codes flag up. It could be a broken wire on the demister. The radio could be a failing antenna
JimJnr72 Posted October 25, 2022 Author Posted October 25, 2022 On 10/22/2022 at 2:37 PM, Steve Q said: I'd recommend a diagnostic check to see if any fault codes flag up. It could be a broken wire on the demister. The radio could be a failing antenna Expand Thanks Steve. I鈥檝e got an ancel vd500 VAG code reader. Should it come up in there somewhere?
Steve Q Posted October 26, 2022 Posted October 26, 2022 I'd like to think it'd come up.witg fault codes. If not then it might need to go.to.an auto electrican
JimJnr72 Posted October 27, 2022 Author Posted October 27, 2022 On 10/26/2022 at 5:05 AM, Steve Q said: I'd like to think it'd come up.witg fault codes. If not then it might need to go.to.an auto electrican Expand Yep, came up with the fault code B126514 Signal for triggering heated rear window interruption/short circuit to ground.
Steve Q Posted October 29, 2022 Posted October 29, 2022 On 10/27/2022 at 5:22 PM, JimJnr72 said: Yep, came up with the fault code B126514 Signal for triggering heated rear window interruption/short circuit to ground. Expand Definitely sounds a wiring issue then. Might be worth removing the trim in the boot to inspect the wires 1
JimJnr72 Posted November 22, 2022 Author Posted November 22, 2022 On 10/29/2022 at 12:59 PM, Steve Q said: Definitely sounds a wiring issue then. Might be worth removing the trim in the boot to inspect the wires Expand So I removed the trims, and everything was disconnected. I鈥檝e reattached everything and all is working. I noticed there are amplifiers on both sides, but there is only a suppressor on one side. Don鈥檛 know if that鈥檚 right or not. Not sure why they have been disconnected. Can only assume it was done when the back window was tinted. 1
Magnet Posted November 23, 2022 Posted November 23, 2022 What is the history of the car James, that may explain the disconnections? Kind regards, Gareth.
