evopilot Posted October 23, 2022 Posted October 23, 2022 anybody know what gearbox oil and how much for our cars? im presuming 75w 90 in a manual c7 tdi ultra? does anybody know how much id need to buy?
Magnet Posted October 24, 2022 Posted October 24, 2022 Hello Andrew, What mileages have these cars covered - to warrant gearbox oil changes? Such changes can be difficult -access wise- and worth considering having done at an independent who will have the information you require. I’m not claiming VAG do, but some manufacturers have their own modified specifications on oil, and such oil may only be available in bulk quantities via. main dealers. Kind regards, Gareth.
evopilot Posted October 24, 2022 Author Posted October 24, 2022 Cheers for the reply Gareth, I'm actually a retired mechanic myself but i come from a Japanese brand dealership so im relatively new to the newer more electric Audis. I only bought this A6 to treat myself. Ive recently done the clutch with flywheel on it so thought id treat the box to new oil 1
evopilot Posted October 24, 2022 Author Posted October 24, 2022 For reference in case anybody stumbles on this thread the original part number is: G052549A2 and the QJY manual gearbox takes 2.5ltrs Castrol also list 75w 90 but i think ill stick to the OE stuff above from Audi 2
Stevey Y Posted October 24, 2022 Posted October 24, 2022 2 hours ago, evopilot said: For reference in case anybody stumbles on this thread the original part number is: G052549A2 and the QJY manual gearbox takes 2.5ltrs Castrol also list 75w 90 but i think ill stick to the OE stuff above from Audi Hi the gearbox oil change is every 50k or two years and I use Fuchs Titan which is whats supplied to Audi but cheaper because its in Fuchs own bottle, my advice would be to get the filler plug out before the drain plug as its a real Barsteward to get out the first time. Steve.
evopilot Posted October 24, 2022 Author Posted October 24, 2022 3 hours ago, Stevey Y said: Hi the gearbox oil change is every 50k or two years and I use Fuchs Titan which is whats supplied to Audi but cheaper because its in Fuchs own bottle, my advice would be to get the filler plug out before the drain plug as its a real Barsteward to get out the first time. Steve. i didnt know the OE stuff was rebranded Fuchs stuff, handy to know. Its like the Halfords stuff is actually Comma oils in a different bottle
Stevey Y Posted October 25, 2022 Posted October 25, 2022 20 hours ago, evopilot said: i didnt know the OE stuff was rebranded Fuchs stuff, handy to know. Its like the Halfords stuff is actually Comma oils in a different bottle Hi thats what cracks me up when people waffle on about only ever buying Audi parts, the whole range is made by someone else and packaged in the Audi boxes so if you want to buy something thats possibly three times the price from the dealer, Knock yourself out, example my oil level sensor £168.00 plus vat from Audi, local motor factor sold me a Febi unit for around £80.00 all in and guess what when I matched the numbers on the casting they were identical except some wag had ground off the dealer logos, Quantum oil is made by Q8, drop links by Lemforder, engine mounts by Febi, I suppose it must be a great consolation when you are pot less knowing you gave your all for the VAG cause. Steve. 1
RoynJess Posted April 15, 2024 Posted April 15, 2024 just spotted this forum so thought i would join in the thread. hello everyone. I own a A6 Avant Ultra C7 2016 which has been a brilliant motor. Bought it four years ago. Although i don't do much mileage it has now done 83ooo Recently had clutch problems so decided to put a complete new clutch in. Not an easy job, but gearbox is now out. Discovered the dual mass flywheel is very poorly. Bought the new clutch assembly and slave/release unit, (not a cheap thing) can't seem to get after sales ones. So this morning i have ordered a new DMF ( wow the price, is it made of gold) So, my point is,, (sorry to be a bit of a bore) i think i will give it some new gearbox oil. Hence, what type of oil ?
kestasa6 Posted November 12, 2024 Posted November 12, 2024 On 4/15/2024 at 2:18 PM, RoynJess said: just spotted this forum so thought i would join in the thread. hello everyone. I own a A6 Avant Ultra C7 2016 which has been a brilliant motor. Bought it four years ago. Although i don't do much mileage it has now done 83ooo Recently had clutch problems so decided to put a complete new clutch in. Not an easy job, but gearbox is now out. Discovered the dual mass flywheel is very poorly. Bought the new clutch assembly and slave/release unit, (not a cheap thing) can't seem to get after sales ones. So this morning i have ordered a new DMF ( wow the price, is it made of gold) So, my point is,, (sorry to be a bit of a bore) i think i will give it some new gearbox oil. Hence, what type of oil ? Hi Any info for oil and where the plugs are locating? QJY gearbox Thank you!
kestasa6 Posted November 12, 2024 Posted November 12, 2024 On 10/24/2022 at 7:15 PM, Stevey Y said: Hi the gearbox oil change is every 50k or two years and I use Fuchs Titan which is whats supplied to Audi but cheaper because its in Fuchs own bottle, my advice would be to get the filler plug out before the drain plug as its a real Barsteward to get out the first time. Steve. Hi Where is plugs locating? QJY manual gearbox...thank you
Stevey Y Posted November 13, 2024 Posted November 13, 2024 19 hours ago, kestasa6 said: Hi Where is plugs locating? QJY manual gearbox...thank you Hi the filler plug is on the passenger side near the drive shaft, the drain plug is at the bottom, the filler plug is a mission to release, you might need to get the car up quite a bit to get enough swing to use a breaker bar. Steve. 1
kestasa6 Posted November 13, 2024 Posted November 13, 2024 1 hour ago, Stevey Y said: Hi the filler plug is on the passenger side near the drive shaft, the drain plug is at the bottom, the filler plug is a mission to release, you might need to get the car up quite a bit to get enough swing to use a breaker bar. Steve. Thank you! Very helpful. As many people said there is no filling plug exist. Regards
Magnet Posted November 14, 2024 Posted November 14, 2024 Sorry Kes, Not understanding ‘…no filler plug exist’.
kestasa6 Posted November 15, 2024 Posted November 15, 2024 Many people saying gearbox filled for a life. There is no filling plug.
Stevey Y Posted November 16, 2024 Posted November 16, 2024 On 11/15/2024 at 7:39 AM, kestasa6 said: Many people saying gearbox filled for a life. There is no filling plug. Hi if you listen to half the garbage that the ill informed spout you would never do anything, my car has exactly the same box and I dont think I had a dream about changing the oil, its simply a case of removing the belly pan and looking for the filler plug where I told you it was, many people who have never attempted this will have an opinion without ever having performed the task, I actually did the first change at 50k the next three were done by my local garage because I am not rolling around in the wet and cold on my garage space, so I supplied the oil and they did it, at the end of the day its your choice as the owner but my gearbox did 270k with no problems. Steve.
kestasa6 Posted November 16, 2024 Posted November 16, 2024 14 minutes ago, Stevey Y said: Hi if you listen to half the garbage that the ill informed spout you would never do anything, my car has exactly the same box and I dont think I had a dream about changing the oil, its simply a case of removing the belly pan and looking for the filler plug where I told you it was, many people who have never attempted this will have an opinion without ever having performed the task, I actually did the first change at 50k the next three were done by my local garage because I am not rolling around in the wet and cold on my garage space, so I supplied the oil and they did it, at the end of the day its your choice as the owner but my gearbox did 270k with no problems. Steve. hi Is it easy to fill? or need some special adapters? i used just hose on my a6 c6 as filling hole was just next to driveshaft ........ Regards Kestas
kestasa6 Posted November 16, 2024 Posted November 16, 2024 1 minute ago, kestasa6 said: hi Is it easy to fill? or need some special adapters? i used just hose on my a6 c6 as filling hole was just next to driveshaft ........ Regards Kestas i just received oil from Audi. a bit pricy but i had bad experiance before when using equvalent oils....so dont want to risk again... regards Kestas
Stevey Y Posted November 16, 2024 Posted November 16, 2024 7 minutes ago, kestasa6 said: i just received oil from Audi. a bit pricy but i had bad experiance before when using equvalent oils....so dont want to risk again... regards Kestas Hi just buy yourself a gear oil filler they have a flexible hose on the end and using the plunger on the filler canister you can put as much or as little as you need also they are not expensive to buy. Steve. 1
kestasa6 Posted November 16, 2024 Posted November 16, 2024 27 minutes ago, Stevey Y said: Hi just buy yourself a gear oil filler they have a flexible hose on the end and using the plunger on the filler canister you can put as much or as little as you need also they are not expensive to buy. Steve. hi ok great will look for it. Thanks allot for your detailed advice. Regards Kestas 1
