Conrad668s Posted November 3, 2022 Posted November 3, 2022 Hi, Had my 2016 allroad for nearly 3 weeks and get occasional engine light with my cheap code reader displaying U0029 Regular mechanic can't get any further with his diagnostics and recommend taking to Audi. Anyone had experience of this code? Cruise control doesn't work and it won't do a regen on dpf either. Using loads of diesel. Google says NoX sensor or canbus issue
Stealth24 Posted January 4, 2023 Posted January 4, 2023 On 11/3/2022 at 8:47 PM, Conrad668s said: Hi, Had my 2016 allroad for nearly 3 weeks and get occasional engine light with my cheap code reader displaying U0029 Regular mechanic can't get any further with his diagnostics and recommend taking to Audi. Anyone had experience of this code? Cruise control doesn't work and it won't do a regen on dpf either. Using loads of diesel. Google says NoX sensor or canbus issue Hi did you ever get to the bottom of this fault ? I have same issue with a q7
evopilot Posted January 22, 2023 Posted January 22, 2023 defiantly a Nox sensor issue, that car cant talk to the sensor for whatever reason The easy one is check the sensor is not dead after that you looking at checking the wiring unfortunately which is a right pain
Conrad668s Posted January 22, 2023 Author Posted January 22, 2023 Cheers. Still waiting on the dealership to arrange repair
stefan1997 Posted October 1, 2024 Posted October 1, 2024 On 1/22/2023 at 11:07 PM, Conrad668s said: Cheers. Still waiting on the dealership to arrange repair Hi bud have you sort it ? What was the issue?
