Mark overton Posted November 7, 2022 Share Posted November 7, 2022 Hi my name is Mark I’m in Los Angles and have lived here since 1975 I’m from Northfield in Birmingham . I have a 2009 A4 Quattro with a 3.2 and my car has a miss on cyl 1 -2-3 that are random . I have replaced all six coils and plugs and both oxygen sensors on bank 1 I cleared the codes a took it for a drive and put about a hundred miles on and came up with the same codes .The car does not lack any power but I do feel the misfire at idle i am wondering if any of you has had the same problem and if they new what could be the cause it only on bank 1 so could it be a cam sensor for that bank. I just don’t know I would appreciate any feed back about this annoying problem thank you Mark Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted November 8, 2022 Share Posted November 8, 2022 20 hours ago, Mark overton said: Hi my name is Mark I’m in Los Angles and have lived here since 1975 I’m from Northfield in Birmingham . I have a 2009 A4 Quattro with a 3.2 and my car has a miss on cyl 1 -2-3 that are random . I have replaced all six coils and plugs and both oxygen sensors on bank 1 I cleared the codes a took it for a drive and put about a hundred miles on and came up with the same codes .The car does not lack any power but I do feel the misfire at idle i am wondering if any of you has had the same problem and if they new what could be the cause it only on bank 1 so could it be a cam sensor for that bank. I just don’t know I would appreciate any feed back about this annoying problem thank you Mark Hi have you had the car scanned and the live data analysed, could be a cam chain problem. Steve. Quote Link to comment Share on other sites More sharing options...
