Panayiotis Posted November 15, 2022 Posted November 15, 2022 I have issue with my borgwarner and i have to replace it. I found a used one from Q7 2006 but it's Garrett . Is any possibility to work?
Stevey Y Posted November 16, 2022 Posted November 16, 2022 On 11/15/2022 at 4:47 PM, Panayiotis said: I have issue with my borgwarner and i have to replace it. I found a used one from Q7 2006 but it's Garrett . Is any possibility to work? Hi if it is the same dimensions as the old unit it will probably work as is all the manufacturers do is swap suppliers every so often, cross check the part numbers. Steve.
Panayiotis Posted November 16, 2022 Author Posted November 16, 2022 8 minutes ago, Stevey Y said: Hi if it is the same dimensions as the old unit it will probably work as is all the manufacturers do is swap suppliers every so often, cross check the part numbers. Steve. Thanks a lot
