Guest Posted November 21, 2022 Posted November 21, 2022 My q7 2008 just back from garage and now a noise i think front drivers side sounds like a tyre inflator buzzing??? Any ideas as never heard this before and i am worried
Magnet Posted November 21, 2022 Posted November 21, 2022 Hello David, Sorry if this comes over as unhelpful, but to be constructive, the shortest route to freedom from worry about this, is to phone the garage and arrange to return the car for inspection at the earliest opportunity. This will result in a much quicker resolution than us guessing on here. I’m sure you will appreciate that it’s virtually impossible to diagnose such noises without access to the vehicle. Perhaps you could let us know how you get on. Kind regards, Gareth. 1
Steve Q Posted November 22, 2022 Posted November 22, 2022 Has it got air suspension? Could it be the compressor?
Guest Posted November 22, 2022 Posted November 22, 2022 Yes it has air suspension. But i have never heard it running before when i got out of the car. I also have never seen the green down arrown on while driving around. I hope its not busted as i hear they are very expensive
Magnet Posted November 23, 2022 Posted November 23, 2022 Hello David, I think Steve may be onto something, and (guess) it maybe an over working compressor. ‘I hear they are very expensive …’ You can bet your last they are! The darlings at Audi want to extract £345 out of my wallet for a piece of moulded foam for the seat base, so with the aid of Percy Verance, we are looking at sensible alternatives. So OK - bad news and compressor problems ( due to the piston ring) - Bagpiping Andy will turn out to be your best friend - look him up on a Google search. He manufactures new rings, and I believe he now supplies reconditioned compressors. I’ve fitted new rings in two non-Audi compressors - not a nice job to access but… Beware of Audi prices, and cheap aftermarket replacements, and put your faith in Andy if you need to. Kind regards, Gareth.
Guest Posted November 23, 2022 Posted November 23, 2022 Scan shows 01583 & 02250 so looks like its time to get a new car
Steve Q Posted November 23, 2022 Posted November 23, 2022 20 minutes ago, Borat said: Scan shows 01583 & 02250 so looks like its time to get a new car What are the codes related to? If there's a leak in the suspension system then the compressor will work overtime to keep the system inflated.
Guest Posted November 23, 2022 Posted November 23, 2022 One says leak detected but it said that last winter also and the other is limit reached. So i guess its pumping up then must have tiny leak somewhere. Also had parking sensors start working again so some major electrical issues going on here aswell
Magnet Posted November 23, 2022 Posted November 23, 2022 Hello David, A leak maybe a minor issue to sort. New car!? Kind regards, Gareth.
