Dean Hassall Posted November 21, 2022 Posted November 21, 2022 I have an a3 2010 auto, the dash has stopped working, I've had it tested but no fault found, all fuses are OK, any one have any ideas please
cliffcoggin Posted November 21, 2022 Posted November 21, 2022 It is not an unusual fault on A3s. They can be repaired by specialist companies for about £200, much cheaper than a new one from Audi. Search on line for such companies. 2
Dean Hassall Posted November 21, 2022 Author Posted November 21, 2022 55 minutes ago, cliffcoggin said: It is not an unusual fault on A3s. They can be repaired by specialist companies for about £200, much cheaper than a new one from Audi. Search on line for such companies. I've had it tested and no faults found, could it be something else
Dean Hassall Posted November 21, 2022 Author Posted November 21, 2022 The dash has been tested and no faults found, fuses are all good
cliffcoggin Posted November 21, 2022 Posted November 21, 2022 Tested by whom, and in what way? That the fuses are OK is irrelevent; it is the circuit board or its components that get damaged as I understand the matter, though I must add that is the full extent of my understanding.
Dean Hassall Posted November 23, 2022 Author Posted November 23, 2022 On 11/21/2022 at 10:41 PM, cliffcoggin said: Tested by whom, and in what way? That the fuses are OK is irrelevent; it is the circuit board or its components that get damaged as I understand the matter, though I must add that is the full extent of my understanding.
Dean Hassall Posted November 23, 2022 Author Posted November 23, 2022 Issue now solved, it was the dashboard, now have my car back, and a life time guarantee on the work 👍
cliffcoggin Posted November 23, 2022 Posted November 23, 2022 1 hour ago, Dean Hassall said: Issue now solved, it was the dashboard, now have my car back, and a life time guarantee on the work 👍 Good. How much did it cost to have repaired if I may ask?
Dean Hassall Posted November 23, 2022 Author Posted November 23, 2022 The total cost was £280, the actual repair for the dashboard was £240
