I have an a3 2010 auto, the dash has stopped working, I've had it tested but no fault found, all fuses are OK, any one have any ideas please
It is not an unusual fault on A3s. They can be repaired by specialist companies for about £200, much cheaper than a new one from Audi. Search on line for such companies.
  • Like 2
I've had it tested and no faults found, could it be something else
Tested by whom, and in what way? That the fuses are OK is irrelevent; it is the circuit board or its components that get damaged as I understand the matter, though I must add that is the full extent of my understanding.
Issue now solved, it was the dashboard, now have my car back, and a life time guarantee on the work 👍
Good. How much did it cost to have repaired if I may ask?
