Hi all
engine management light has just come on put the code reader on and its coming up with codes
PO401 and Po401P
after googling the code problem seems to be EGR valve
is it a case of replacing the EGR valve or could it be something else causing the codes ?
any advice appreciated before i take to a garage
Egr valve failure is common. It's not a cheap job. You could try and get it cleaned but this may only rectify the issue for a short time.
