Oopsitsbrokenagain Posted December 1, 2022 Posted December 1, 2022 My parking sensors are working very intermittently, more often than not when I go into reverse there's a loud and constant beep for a couple of seconds and then it stops, when it does this, the parking sensors do not work. Sometimes when I go into reverse there is no beep at all and the parking sensors do not work. And very very occasionally I get a small singular beep when I go into reverse and this is the only time the sensors work. Does anyone know what the cause of this might be? I drive a 2007 A4 Avant S-line
Magnet Posted December 1, 2022 Posted December 1, 2022 Hello Paddy, Thanks for joining and posting your plea. As you probably know, the ‘signal’ that the reversing sensors are going to work is a short bleep when you go into reverse. A long 10 secondish bleep when selecting reverse indicates a fault. When you don’t get any bleep when selecting reverse then you suspect the reverse switch itself. So, first thing - are the reverse lights working every time? Please report back on this. If they are working correctly then two possibilities:- one or more faulty sensors in the bumper. Some say you can hear the good ones buzzing when in reverse, or indeed feel them vibrating, so you might be able to find the faulty one out of these 4 -? . That hasn’t worked for me! Second possibility is the reverse parking module which usually lives behind the o/s boot side panel. How do you fault find? ( assuming you have tested that the reverse lights are operating). Diagnostics I’m afraid, unless you just throw a full set of sensors at it and hope! Diagnostics will pin point the actual sensor at fault, and the system seems to work on one-out-all-out. New sensors -around £160 each from Audi ( no the 0 isn’t a typo!). eBay ( try Parkingsensors Direct) - possibly less than £13 each, and you will probably find they will be embossed with the actual Audi part number! Oh, you will need the part number. Those doing the diagnostics should be able to give you that. Bad news:- likely the bumper will have to come off if it’s a centre sensor at fault. Let us know how you get on Paddy. Kind regards, Gareth. p.s. some advocate a good spray dose of WD40 into each sensor. Wishful thinking, but worth a try.
Magnet Posted December 3, 2022 Posted December 3, 2022 Hello Paddy, Just wondered if any of the advice given to you is, or will be of any help? We notice you have returned to the forum and no doubt have read it. Kind regards, Gareth.
Jimm Posted February 5, 2024 Posted February 5, 2024 I have this on my 2007 Estate. Where is the reverse parking module located? I'm assuming this as I have no response from any of the sensors, that I can feel. Lights work in reverse, also. Thanks
Magnet Posted February 5, 2024 Posted February 5, 2024 Hello James, Welcome and many thanks for joining. Hope you have better luck than Paddy, who must have been too affected by all of this to even acknowledge - leave alone offer thanks for the advice given! This advice will still stand for your situation. ‘..I have no response from any of the sensors…’ What response are you looking for James? My take on this ( if you have the same symptoms as Paddy) is that one or more of the sensors are at fault. Module failures are much much rarer. Module is usually located in the boot side - probably driver side. I think you will need 5 mins with the diagnostic to indenting the culprit sensor. Perhaps you could let us know how you get on. Kind regards, Gareth.
Jimm Posted February 5, 2024 Posted February 5, 2024 Quote 52 minutes ago, Magnet said: What response are you looking for James? I was under the impression that they should buzz, ever so slightly when reverse is selected?
Magnet Posted February 5, 2024 Posted February 5, 2024 I read that somewhere too, but in my experience - no. Probably written by someone with some modules they want to sell! Kind regards, Gareth.
Jimm Posted February 6, 2024 Posted February 6, 2024 So what's the method in locating the faulty sensor? Thanks for the help, too!
Magnet Posted February 6, 2024 Posted February 6, 2024 Hello Jason, Sorry to contradict, but as stated, I too read about audible signals, but not necessarily so, as the song goes. It may work for you, but I’ve not be successful. Guaranteed way would be to carryout diagnostics to find the culprit. Re. removing the senders, you are likely to find they go in in compressible ears, and these have to be compressed to remove. Removing the electrical connectors are again likely to lead you a dance. Kind regards, Gareth.
Jimm Posted February 7, 2024 Posted February 7, 2024 On 2/6/2024 at 1:01 PM, jasonj said: Hope this has enlightened you . Jasonj Thanks for taking time, Jason. I'll report back once I've tried this. James
Jimm Posted February 7, 2024 Posted February 7, 2024 Thanks also, Gareth. If I can't locate again, I'll remove each and try mu multimeter.
