Gag S Posted December 14, 2022 Posted December 14, 2022 Hi driver side heating it’s blowing cool while passenger side is blowing hot any ideas plugged it fault code is coming up as B201000 any response will be greatly appreciated thanks
Tigger Posted January 3, 2023 Posted January 3, 2023 Hi 'Gag'(?) Brief research would suggest "B20100" (sometimes shows up with explanation "Basic Settings Missing") equates to one of the Flap Motors having an issue, or having failed entirely... And as it is the flaps that move to mix hot/cold air to give you the desired temperatures, that would seem to match your symptoms. I can't even imagine how much work it is to dig out and replace one of those behind all that dashboard! I hope you find a cheap fix... Regards, Tigger
