the trucker68 Posted December 31, 2022 Posted December 31, 2022 Just changed battery in key fob, light flashes but will not unlock car, any ideas please
Steve Q Posted December 31, 2022 Posted December 31, 2022 Try reprogramming the key via this YouTube video: Also if you have a spare key you could try and use that, as it might help narrow down whether the issue is with the key or the car. If that doesn't work then I'd recommend a diagnostic check to see if any fault codes flag up
Mark b7 Posted January 1, 2023 Posted January 1, 2023 Put key into ignition turn key while holding down the lock button on the fob turn off ignition while still holding button down take key out and fob should work this way worked for me . 1
